nofarb17 wrote:
Direct3d 10 is only available for Vista and Win7, so does this software actually work on Windows XP.
Yes it does work on Windows XP.
nofarb17 wrote:
The ipisoft product page says that the software can use windows XP, but requires a direct3d 10 video card.
Yes, it's true. You need a DirectX 10-compatible video card for running this software, even under WinXP. This is a GPGPU software (it does calculations on a video card). It requires a video card with serious support for 32-bit floating point math. Existing DirectX 9 cards only support 24-bit FP math. So you need a DirectX 10 card despite the fact that our software uses DirectX 9 API.
nofarb17 wrote:
having to do several thousand dollars worth of hardware and software upgrades would make it impractical
You can get a decent mid-range DirectX 10 video card for around $100.
nofarb17 wrote:
Does anyone know if the free trial period software will handle a 6 camera solution?
Trial version supports up to 4 cameras. You will be able to preview capture results for 6-camera video but you won't be able to export animation for it.
nofarb17 wrote:
If I do a 6 camera shoot, can I have the ipisoft software only use the video from 4 of the cameras when I process it later into mocap data?
Theoretically you can edit your video and cut extra cameras. You can use VirtualDub for editing (it is free).
