It is currently Sun Nov 08, 2026 8:33 pm
PostPosted: Wed Aug 17, 2011 1:00 pm
Здравствуйте! Я использую ipi recorder не для ipi studio, а для простой записи видео с двух камер в режиме((Raw Bayer Mode)без этого режима не получается снять 60фпс с двух камер)), на выходе у меня получается видеозапись разделенная на 8 черно-белых видео, это все понятно(формат такой), но вот вопрос: Как совместить эти видеозаписи в одну цветную, есть ли видео редакторы понимающие этот формат или конвертеры?
PostPosted: Thu Aug 18, 2011 3:10 am
I tried some of the tools here, but i can't get it working. It would be nice if it just could be done in After Effects.
http://www.theimagingsourceforums.com/s ... g-AviSynth
http://forum.videohelp.com/threads/3379 ... (grayscale)-to-Xvid-(color)?p=2100059&viewfull=1
http://forum.doom9.org/showthread.php?p=1268990
PostPosted: Tue Aug 30, 2011 3:05 am
I have a tool can do that ,but i do not know how help for this tell me i can help you
my email 635342190@qq.com
PostPosted: Thu Sep 01, 2011 4:44 am
http://arnholm.org/astro/software/aviraw/
Shouldn't this be able so save the avi in a debayered format? It doesn't work either.
Anyone got an idea why?
PostPosted: Thu Sep 01, 2011 5:54 am
very very easy
PostPosted: Thu Sep 01, 2011 6:51 am
So how did you do that? Please post the way / tool.
PostPosted: Thu Sep 01, 2011 8:59 am
"Boilsoft Video Splitter" make a range ,video clip (must)
"Adobe After Effects CS3 Professional"(must)
I do not know why ,but ,success,oops ,remember me I am a chinese come from lianyungang
635342190@qq.com email me if .....somewhere wrong ,tell me ,I can help you
PostPosted: Thu Sep 01, 2011 9:37 am
But it's not debayered at all. The YUY2 records work without it but you won't get 60fps for multiple cams. Did you capture as RAW Video with iPi Recorder?
PostPosted: Thu Sep 01, 2011 10:27 am
you can use two or there computer to get better result, because the fps was base on your computer or better cameras,then import into AE and,then composite it ,output file use in iPiStudio just set the size , ok ipistudio can recognized it,multiple cameras 60 fps or up ok or use other capture tools, And ..........
PostPosted: Thu Sep 01, 2011 10:53 am
Yeah i know. But i try to do facial capture and for that i need the debayered records to use them in a tracking software. I don't want to use an additional computer because than you will have to sync the records.
Users browsing this forum: Baidu [Spider] and 42 guests
