MrBones YOU ARE A GENIUS! I saved the files as BMP instead of jpeg (jpg) and it reads the images just fine.
So here is what I'm finding out:
Record your video. Any camera will do - I used the PS3 Eyecam
Import the sequence into Photoshop as frames.
Save as BMP
Import the sequence into Moviemation (it takes it a bit of time)
Import just the facial rig from your character as an OBJ
Highlight the markers. (Free version gives you 12 markers while the purchased version gives you about 32)
Let it scan - this process works similar to Ipi.
Save the sequence then attach to your character in whatever program you want (Poser, DAZ, Blender)
You can use basically anything for markers, however I found these brilliant little half spheres with sticky glue on the flat surface at an art supply store. You can order them from this website as well - they are about 8mm -
http://eksuccessbrands.com/jolees/Products/Pearl_Border_Stickers_50-00202.htmJust make sure that the face has been cleaned from oil and dirt. It also doesn't hurt to use a bit of liquid latex or spirit gum to assure they will stay on. But for the purposes of this test they work just fine.
As soon as I can post some video I will. I wish we could post photos on this forum :)
