It is currently Sun Nov 08, 2026 6:05 pm
PostPosted: Sun Nov 06, 2011 3:36 pm
I would need the iPi to come up with a pre set of preferences.
Meaning, When I start iPi.
The Grid is off, background set to dark blue, skeleton strobe off, and showdepth enabled.
THis is because it takes about 15 seconds to do this everytiime I open iPi.
I want it to be exactly how I want it when it starts.
I think it would be called Preferences...under edit menu. or Control P.
Thanks
PostPosted: Sun Jan 22, 2012 6:46 pm
I wholeheartedly agree! Even if it was a text based ini file we had to manually create that would be better than having to change your settings every time you start the program. Sometimes I forget to check shoulder tracking and don't realize it until the process has been going for several minutes...time wasted.
Thanks,
Mitch
Users browsing this forum: No registered users and 82 guests
