It is currently Mon Jul 27, 2026 8:08 pm
PostPosted: Mon Nov 28, 2011 6:35 am
Hi everyone,
I ran in to a little problem with my dual Kinect Setup. One of the Kinects output is different in scale.
I tested them with the Viewer from Kinect RGBDemo.
I get different Distances for the same point in space. The difference is about 15 centimeters.
AFAIK OpenNI uses the Hardware Calibration directly from Kinect Sensor?
Could it be that one of them is just wrong? is there a way to change it?
PostPosted: Mon Nov 28, 2011 10:45 am
Hello!
Could you please share this calibration video with us?
PostPosted: Mon Nov 28, 2011 11:23 am
andrew wrote:
Hello!
http://www.youtube.com/watch?v=PszvU4VkUMA for how to calibrate 180 degrees.
PostPosted: Tue Nov 29, 2011 3:16 am
andrew wrote:
Hello!
I deleted the one i took the screenshot from, so i made a new one. It's not as good as the others i did (some lags) but it has the same problem with the scale.
https://rapidshare.com/files/1852935716/video_2011-11-29_10-25-21.rar
PostPosted: Tue Nov 29, 2011 4:19 am
Thank you for sharing this video.
It looks like that your problem is "too much yellow". That is too much pixel in which there is no data about depth. As a result ground (floor) plane can't be determined correctly (too little data about floor points). This is the root problem rather than scale.
Tip: try to move your Kinects and/or cover floor with some material (carpet, paper) to minimize amount of yellow on the floor area.
PostPosted: Tue Nov 29, 2011 4:39 am
Hi Andrew,
thank you for trying to help me.
I think the yellow points aren't really my problems. I did made a Screenshot from my first calibration tests before i deleted them.
There should be enough points on the ground?
There's another problem with the Kinect on the right Side. This happens sporadically for a few seconds but i can live with that for the moment, the scale issue is more problematic :)
PostPosted: Tue Nov 29, 2011 4:53 am
Ok, we'll discover this video in more details.
By the way, problems with right Kinect on your screenshot can concern USB issues. Try to use different USB adapter and make sure that there isn't other device (flash drives, mouse, etc) on the same USB hub.
PostPosted: Tue Nov 29, 2011 11:33 am
Hi Scalp,
Is RGB enabled under your preferences?
And your not using one of those after market things on your Kinect Sensor for scale are you?
PostPosted: Wed Nov 30, 2011 3:19 am
Hi mrbones,
i didn't know until now that there are "zoom lenses" for the Kinect. So no, i´m using standard Kinects. But they were used by some other guys who did a lot of stuff with openNi. Maybe they changed something in Firmware.
I also have the development Version of the Asus Primesense Sensor, but the iPi recorder doesn't recognize it. Which ist quite understandable :)
The reasons for my USB problems are probably my slow HDD on my Labtop and or as andrew wrote the wireless mouse adapter i´m using. That should be easy for me to fix.
PostPosted: Wed Nov 30, 2011 12:16 pm
Hi Scalp,
its me Tommy.
Did you fix your problem?
best regards Tommy
Users browsing this forum: Google [Bot] and 32 guests
