It is currently Tue Jun 30, 2026 3:44 am
 Post subject: I can't get 640 x 480
PostPosted: Thu Dec 08, 2011 4:12 pm
Hi, we have been using iPi at DigitalDimension for a few weeks now, and I must say that it works pretty well and it is a wonderfull tool for our animation team, but there is somehing that have been bothering me.
When I capture the videos, I always try to capture a 640x480 video, with 6 PS3Eye cameras, using diffenrent framerate. It seems to wotk just fine, but, when I look at the video's resolution, I always get 1920x960.
So if we divide 1920 by 6 and 960 by 4, we get 320 X 240... So where is the error? Where is my 640x480? I have the same issue if I try with less camera.
Would I get 640x480 with a better computer or there is just something that I don't get?
Here are my computer's specs:
System Type: x64-based PC
Processor(s): 2 Processor(s) Installed. ( 2 x Quad Core )
[01]: Intel64 Family 6 Model 26 Stepping 5 GenuineIntel ~2394 Mhz
[02]: Intel64 Family 6 Model 26 Stepping 5 GenuineIntel ~2394 Mhz
Total Physical Memory: 12,286 MB
Available Physical Memory: 10,338 MB
Virtual Memory: Max Size: 24,569 MB
Virtual Memory: Available: 22,568 MB
Virtual Memory: In Use: 2,001 MB
NVIDIA GeForce CTX 275
Total Available Memory: 5374MB
Dedicated VIdeo Memory: 1792 MB
System Video Memory: 0MB
Shared System Memory: 3582 MB
Thank you
PostPosted: Thu Dec 08, 2011 6:45 pm
That's actually correct and it has to do with how the data is stored in each channel when using RAW Bayer. When using RAW Bayer, a pattern used in the channels so that when all channels are combined and properly interpolated (or debayered,) it forms a full 640 x 480 resolution image. This is not a scaled image but an actual 640 x 480 image.
I seem to recall that there was a more technical explanation of this a while back in these forums but that's my 'layman's' version. :)
If you want more info, look here:
http://www.weisscam.com/lexicon/b/bayer ... ering.html
This probably explains it better than I can.
PostPosted: Fri Dec 09, 2011 7:27 am
Mystery solved, thank you!
Users browsing this forum: No registered users and 38 guests
