It is currently Sun Nov 08, 2026 9:10 pm
PostPosted: Mon Jan 02, 2012 6:28 pm
When I use the usb cables I have to move the Kinect devise far back as possible the kinect doesn't work.
IS there a special kind of cable to get?
Can I use a powered USB hub and a very long extension for a printer with the square end on the other side ?
PostPosted: Mon Jan 02, 2012 10:25 pm
You'll need an active usb extender. The passive ones are just extension cables and the signal becomes unusable after a certain distance. The active ones boost the signal. You could probably use a powered USB hub as an extender. If you have one, let us know how it works. If not, powered extenders are fairly cheap, there's a link to one on newegg in one of the recent posts.
EDIT: Here's the link to the post: viewtopic.php?f=2&t=5704
Users browsing this forum: Baidu [Spider] and 61 guests
