It is currently Sat Aug 15, 2026 12:18 pm
Post a new topicPost a reply Page 9 of 10   [ 99 posts ]
Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
 Post subject: Re: iPi DMC 2.0
PostPosted: Sat May 19, 2012 9:55 pm
I'm really confused someone clear this up for me, so the tracking is there built into ipi but its just not accessibly until v2?
Cra0kalo
Lead of Operation Reaper
http://projectreaper.com
PostPosted: Sat May 19, 2012 10:14 pm
No.
This is not true.
PostPosted: Sat May 19, 2012 10:39 pm
Michael Nikonov wrote:
No.
This is not true.
then how come those videos show the tracking working in the older version
Cra0kalo
PostPosted: Sat May 19, 2012 11:22 pm
They do not show that.
What they show is not automatic tracking.
We don't mind if our users use the hack shown in those videos. We just cannot officially recommend it because it is not very practical. If we recommended it, it would look like we are trying to sell unfinished functionality.
PostPosted: Sun May 20, 2012 9:02 am
To me, the technique in the video appears to be an 'iPi DMC' variation of manual matchmoving or 'rotocapture', where the animator visually matches the position of limb to what he sees in a background video (or in this case a 3D point cloud.)
This technique is definitely not the same as tracking, at least not in the way iPi DMC automatically tracks motion. Rotocapture is a technique we used to use back when didn't have access to motion capture equipment or services. It'a a 'brute force' technique you can do in any 3D animation program--'old school' but still useful. If you need to animate an entire body, rotocapture can be tedious but it's not so bad if you're only concerned with one extremity like the head.
Anyway, short answer: iPi DMC does not automatically track the head motion for you like it does with the arms, legs, and torso. It does let you rotate the head joint manually, like you can with other joints.
IMO, if you're going take the time to manually animate the neck and head joints, it's easier to do this in a 3D animation program. For example, in many 3D programs, you could set up a target object for the head to 'look at' and simply animate the position of the target. This way you can can get the character to look exactly where it should be looking. (When using original mocap data, chances are good that your character is not going to be looking where you want when it's imported to your 3D environment, and you'll probably want to manually edit the neck/head rotation anyway.)
My understanding is that iPi Soft plans to introduce automatic head and wrist tracking in iPi DMC 2.0, which will track the way version 1.0 currently does for arms, legs, and torso.
Hope that's a little more clear.
G
PostPosted: Tue May 22, 2012 8:14 pm
G
ahhh makes sense now
Cra0kalo
PostPosted: Fri May 25, 2012 1:36 am
is there allready a new release date, cause May will end soon and i'm realy interessted in the new features.
PostPosted: Fri May 25, 2012 7:10 am
So there will you on this, I'm starting to lose my excitement about v2.
PostPosted: Sat May 26, 2012 8:27 pm
I think the new features just released in the Kinect SDK 1.5 maybe a source of delay. This should greatly speed up the head and hand tracking implementation. The facial mocap and other features would probably take more time.
PostPosted: Tue May 29, 2012 1:04 am
yeahh ... i'm quite happy about the 1.5 release, but i think this new features will arrive in ipi 2.5 or something like that.
don't think this will have any affect to the actuell release... think the guys currently sitting on bugfixing ...
anyway. we tested with eye-cams and kinect. plan is to capture with the eye-cams, cause of the bigger volume.
would be nice to hear something about the release, cause this software, and also me, lose actually a lot of standing in the studio i worked.
in march i shift a production to the future, cause of the new release. end of april i said to a eye-rolling supervisior that the release is shifted to May and now it looks like maybe June.
Just wannt to get an info, cause we lose time.
Users browsing this forum: No registered users and 22 guests
