It is currently Mon Sep 21, 2026 4:29 am
PostPosted: Sun Feb 10, 2013 9:59 pm
I think a useful feature might be batch-processing files.
I would like to open up a project, align the T-pose, set region of interest.
Then I would open several more, doing the same
Then, after adding these to a batch list, the software would open each project, and track match forward.
Naturally there will be tracking errors, but at least I could be using those cores while I sleep ;)
Batching could also be used for refining animation, smoothing trajectories in later steps.
PostPosted: Mon Feb 11, 2013 2:25 am
There's been a request like this at least 18 months but still nothing? I tried v2 when it came out last summer and was disappointed by the fact that it seemed considerably slower and still didn't have batch processing of any kind. Of course, if you have enough resources you can run several instances at the same time - but then you cannot do anything else that requires a lot of resources. V1 also crashes every time you press CTRL+ALT+DEL so you need to remember to stop the tracking while you need to lock the screen for example.
In short, batch processing vote: +1
PostPosted: Mon Feb 11, 2013 6:55 am
Hi guys
We did not consider batch processing earlier exactly because our tracking process is not good in automatic recovery after errors. And usually after one of the firsts error, all subsequent tracking results are useless - e.g. the model flies away somewhere.
As you continue to insist :) I think we may consider this feature for v3. However, first we will concentrate on computing speed improvement.
PostPosted: Mon Feb 11, 2013 9:36 am
As you know, I'd asked for this as well many years ago. I still feel that way, though maybe a lot less so since iPi tracks so much faster now. (Back then, it took 10 times longer or more to 'rough track' a scene.)
Anyway, I think if the user is confident that iPi Mocap Studio will get through most of the footage without errors, batch processing is certainly worth considering.
For example, my typical workflow during 'Happy Box' was to just let iPi do an unsupervised 'rough track' and then come back several minutes later to fix any problems. This obviously works for simple motions but that was certainly the case during 'Happy Box'--I did have to edit motions in my animation program but there was actually very little error correction required in iPi Studio. The only shots that required constant supervision during tracking involved the 'spinning chainsaw dance', which of course, was a fairly complex motion for two front positioned Kinects to follow.
It's been a little different for the capture used in Brudders 2 though. I don't think the motions in this production. In Brudders 2 the characters are more active and they're performing very specific motions that need to be tracked accurately, so this time I'm having to pay much closer attention during the track. In this situations, batch processing is less useful.
So, batch processing can be a good option to have in some situations and probably a waste of time in other situations, but it will be nice if the option was there to be used when needed.
But I agree--I'd much rather see some specific bug fixes and overall speed improvements first. :)
Users browsing this forum: No registered users and 15 guests
