It is currently Sun Nov 08, 2026 5:11 pm
Post a new topicPost a reply Page 2 of 2   [ 16 posts ]
Go to page Previous  1, 2
PostPosted: Wed May 08, 2013 7:08 pm
Quote:
How much do you move the board? The movements range should be at least half meter.
A good amount but not too far... Probably at most half a meter...I'll try more distance on the movement of the card. I'll let you know how it goes. Thanks! :)
PostPosted: Fri Sep 06, 2013 7:58 am
The more you can move it the better. In addition to telling the system this is a 180 configuration, the deeper z-movement of the board makes it clearer to software which Kinect is the 'front' device and which is the 'rear'.
PostPosted: Sat Sep 07, 2013 12:16 pm
In the latest version new calibration approach is introduced: http://wiki.ipisoft.com/Dual_Depth_Sensor_Calibration_using_Flashlight. You can try it.
PostPosted: Sat Sep 07, 2013 2:12 pm
The new calibration sounds interesting. The instructions are vague about the situation in which this method may work better than the board method--could you clarify?
Thanks in advance for info! :)
PostPosted: Sat Sep 07, 2013 11:51 pm
It depends on board size and surface structure, also it depends on depth map quality from sensors (their mutual interference). Besides, now we performed only our own tests for limited number of configuration and sensor models. It's worth to wait for users feedback.
But I should say that based on our internal tests new approach looks very promising.
PostPosted: Sun Sep 08, 2013 10:39 am
Thank you for the info Andrew, that was very helpful.
I'll try the new method in our next capture session and be sure to let you guys know how well it works for us. (Which should be in a three or four weeks. Currently I'm distracted by another short film project for Gothtober but we're hoping this one gets done quickly because there's is no cg involved--then it's back to iPi and finishing 'B2'.) :)
Users browsing this forum: No registered users and 80 guests
