It is currently Sun Nov 08, 2026 10:39 pm
Post a new topicPost a reply Page 2 of 2   [ 19 posts ]
Go to page Previous  1, 2
 Post subject: Re: Xbox Kinect Info?
PostPosted: Sun Jan 23, 2011 6:13 am
Hello!
As to demo: we have published the following video (several weeks ago): http://www.youtube.com/watch?v=GCu8KTrC4sc.
As to exact date: it depends. We still have some issues which involves research with unpredictable results. Also we don't decide yet about beta version: to publish or not to publish release candidate.
As to comparison with plugin for MB from brekel.com: our main advantage is higher robustness and accuracy and as a result more realistic and solid result animation. Also our decision is not limited by one 3d package. Meanwhile disadvantage is processing speed (offline, not real time). Note that this is only our observations and we hope you'll be able to make your own view as soon as we publish our new software.
PostPosted: Sun Jan 23, 2011 2:11 pm
as long as the kinect version runs on vista and can output biped (3dsmax) BVH friendly files i'm "in"
PostPosted: Mon Jan 24, 2011 9:45 pm
This is really really good news!
I have test Brekel plugin for Motion Builder. It works very well, but the main problem is on the foot sliding. I hope that it can be solved completely with ipisoft kinect!
Do you have plan to use two camera kinect system? If it can be realized, that would be awesome! I think you must have algorithm for synchronizing more than one camera so that would be the first motion capture with more than one kinect.
Thank you.
Iwan Suryolaksono
PostPosted: Thu Jan 27, 2011 9:49 am
So does this mean the motion capture will not be realtime through the Kinect? We will need to capture what the Kinect sees and then process offline like the older software setups?
"Meanwhile disadvantage is processing speed (offline, not real time)."
Thanks,
The Lorax
PostPosted: Thu Jan 27, 2011 10:05 am
Yes
 Post subject: Two questions
PostPosted: Fri Feb 11, 2011 4:51 am
Hello Andrew !
On 22th of january you wrote: "...Right now we are in a hurry to release Kinect version in early February..." .
Right now it´s early February - when will it released?
Which Kinect-drivers will be used by iPiMoCap - OpenNI?
Kind Regards
Tezen
PostPosted: Fri Feb 11, 2011 5:00 am
Hello!
Next week we'll publish beta version.
Beta version will support only libusb-win32 drivers (compatible with OpenKinect). As soon as status of OpenNI drivers for Kinect will be clarified we'll add support for them.
PostPosted: Tue Feb 22, 2011 4:20 am
Hello!
A couple days ago we have published version with Kinect support in
beta status. For more info about it see wiki-page:
http://ipisoft.com/en/wiki/index.php?title=Quick_Start_Guide_with_MS_Kinect_Sensor
We plan to release Express edition in a couple of weeks or in a month
- depending on results of beta testing.
PostPosted: Thu Feb 24, 2011 2:48 pm
Suggest you create a new forum for Kinect information and feedback. There are now several threads all with disparate Kinect information.
It would probably be tidier to have it all in one place for both developers and customers. :)
Users browsing this forum: No registered users and 99 guests
