It is currently Wed Jul 01, 2026 5:05 am
Post a new topicPost a reply Page 2 of 2   [ 16 posts ]
Go to page Previous  1, 2
PostPosted: Thu Oct 27, 2011 4:48 am
atmuc wrote:
is there any way to use just cpu?
Then processing will be 25x times slower. Modern GPU more powerful than modern CPU for algorithms with high level of parallelism.
PostPosted: Thu Oct 27, 2011 11:21 am
Which brings me to the question:
Will there be support for multiple GPUs? Just curious if we were to build a dedicated box for mocap.
PostPosted: Thu Oct 27, 2011 11:23 am
We hope so. At least this feature exists in our "near-future" road map.
PostPosted: Thu Oct 27, 2011 11:44 am
Very cool. Thanks for the reply.
PostPosted: Thu Oct 27, 2011 9:24 pm
I thought it had to to with seek times on the hard drive.
It will go a little faster if you use a second hard drive to process your recordings.
PostPosted: Fri Oct 28, 2011 2:33 am
You can't really say which one is better because they are both excellent. It just depends on what you're needs are, if you’re trying to capture a walk cycle or some motion that uses all the X Y Z Axis then the ps3 camera system is the best option for you. If you're capturing some kind of gesture motion let’s say someone waving then the Xbox Kinect camera is the option you should go with, it can be done with the PS3 camera setup but the PS3 camera setup requires calibration and setup. In the end what system is "better" comes back to you and your needs and wants.
Cra0kalo
Offical Machinima.com Director
http://youtube.com/user/cra0kalo
Lead of Operation Reaper
http://projectreaper.com
Users browsing this forum: Google [Bot] and 149 guests
